    Multi Thread Handling for normal Processes using python
    Raspberry Pi
    8964
      Hello all,
      I would like to know whether we can handle two different processes using python? like how our usual OS's do. For instance, I am using raspberry pi for reading video frames and at the same instance I'm handling a function where I am playing audio on speaker. Can I do both the things at the same time using two different individual threads on raspberry pi?
      If yes, please suggest me how can I achieve this. Thanks in advance..!!
      • J
        jerinisready last edited by jerinisready
        I suggest you multiprocessing to handle dlifferent processes.
        Use multiprocessing.Process.
        If you want to establish a communication between parent and child process, use multiprocessing.Queue or multiprocessing.Pipe
          @jerinisready Thank you soo much. Is Multiprocessing.process is an python library? Can i get it through PIP installer?
          J 1 Reply Last reply Reply Quote 0
            Hi @kowshik1729 ,
            Yes, you can do Multi Thread in Raspberry Pi using python and note that different threads do not actually execute at the same time: they merely appear to.
            We can easily implement simple threads using threading module. I'll show you some example of how actually it works.
            Example :
            I was trying to blink two LED's at the same time, for that I created a function that does the blink infinitely using while(True) .
            import RPi.GPIO as GPIO
            import time
            Rled = 12
            Bled = 6
            GPIO.setmode(GPIO.BCM)
            GPIO.setup(Rled,GPIO.OUT)
            GPIO.setup(Bled,GPIO.OUT)
            def blue():
                    while True:
                            print "LED BLUE is  ON"
                            GPIO.output(Bled,GPIO.LOW)
                            time.sleep(1)
                            print "LED BLUE is  OFF"
                            GPIO.output(Bled,GPIO.HIGH)
                            time.sleep(1)
            def red():
                    while True:
                            print "LED RED is  ON"
                            GPIO.output(Rled,GPIO.LOW)
                            time.sleep(1)
                            print "LED RED is OFF"
                            GPIO.output(Rled,GPIO.HIGH)
                            time.sleep(1)
            blue()
            red()
            Output :
            Video : https://www.youtube.com/watch?v=AypMEQFpEWo&feature=youtu.be
            since we are using the infinity loop for both methods, the blue() will not stop and red() will not invoke either.
            In these scenarios, we can use multithread both function without waiting for another , let's try.
            import time
            import threading
            Rled = 12
            Bled = 6
            def blue():
                    while True:
                            time.sleep(1)
                            time.sleep(1)
            def red():
                    while True:
                            time.sleep(1)
                            time.sleep(1)
            t1 = threading.Thread(target=blue)
            t2 = threading.Thread(target=red)
            t1.start()
            t2.start()
            Output :
            Video : https://www.youtube.com/watch?v=HMKYzgdNwd8&feature=youtu.be
            with the help threading module we can simply run both methods at the same time (how we feel).
            I think you got your answer. also, keep in mind to avoid race condition and deadlock while multithreading.
            • J
              jerinisready @kowshik1729 last edited by jerinisready
              @kowshik1729
              that's builtin at python. only thing is. you can simply import using
              from multiprocessing import Process
              def my_function_to_run(*args, **kwargs):
              def main():
                  p1 = Process(
                                 target=my_function_to_run,
                                 args=('arg_01', 'arg_02', 'arg_03', ),
                                 kwargs={'key': 'value', 'another_key':True}
                  p1.start()
                  p2 = Process(
                  p2.start()
                  p1.join()
                  p2.join()
                  print("Finished!")
              if __name__ == '__main__':
                 main()
              This Might can help: https://docs.python.org/2/library/multiprocessing.html
                @salmanfaris Thankyou soo much for awesome example. The video really helped me what it looks like without multi threading. Thank you.
                  salmanfaris @kowshik1729 last edited by salmanfaris
                  @kowshik1729 happy hacking and keep making.
                  all the best 😊 👍
                  • Hi @borncurious , For the industrial purpose you can go with Raspberry Pi compute modules, Take a look at the latest version CM4 - https://www.raspberrypi.com/products/compute-module-4/ , Which is designed for industrial usage and incorporates a quad-core ARM Cortex-A72 processor, dual video output, and a wide selection of other interfaces. Available in 32 variants, with a range of RAM and eMMC Flash options, and with or without wireless connectivity.
                    Other options are, boards like RockPi and Orange Pi boards which are similar to Raspberry similar model and specs but the price is a bit lower than the raspberry pi. Make sure to check the Interface and driver support that you need to incorporate into your project since these boards are not documented and maintained like the official raspberry pi as far as I know.
                    also, you can check Toradex System on Module.
                  • B
                    Is raspi generally used in commercial product/end product.if not can u guys suggest raspi alternatives for end products.
                  • https://www.youtube.com/watch?v=1EIFfln3Kxs&t=1s
                    The classic compact camera for Raspberry Pi with a 12MP sensor and autofocus
                    Available from $25 with your choice of standard and wide lenses, with or without an infrared filter
                    More details: https://www.raspberrypi.com/products/camera-module-3/
                    https://youtu.be/XwYRSlqCN3A
                    Resource:
                    Documentation: https://www.raspberrypi.com/documentation/accessories/camera.html
                    Camera Software: https://www.raspberrypi.com/documentation/computers/camera_software.html
                  • Hey @rafitc99 ,
                    Did your issue resolve? Curious to know 😊
